MajBach
- Jun 21, 2003
- 564
Hi, everyone. Been a long time since I was here - I guess thats a good thing. I have a 305 Mercruiser Alpha 1 on a Maxum 2300. Last year the trim up stopped working but, if I pressed harder, it would go into tilt mode and worked fine. It goes down fine as well. I assume the problem is in the switch. Took it apart today and looks like not a simple job as the switch is a sealed unit and the wires disappear well behind the wall. I just wanted to make sure I don't go through the trouble of ordering a switch, replacing it and then finding out the problem is at the motor. Is there a way of testing it?
Also, what kind of oil goes into the trim?
Thanks
Thanks
