tilt and trim
Indymike
At the risk of sounding stupid what is the difference between tilt and trim on an OB motor?<br /><br /><br />Thanks,<br />Mike
Barnacle_Bill
Re: tilt and trim
Tilt raises or lowers the motor like for trailering. Trim, adjusts the tilt for max performance. Hope that makes sense.
Indymike
Re: tilt and trim
So the tilt is all or none and the trim is the adjustment within that full range ?<br /><br />Thanks,<br />Mike
2cycle
Re: tilt and trim
So the tilt is all or none and the trim is the adjustment within that full range ?<br /><br /><br />Yes, for example, my old mercury has a "trim limit switch" that opens the circuit once the limit is reached when on plane and trimming the motor up for best performance. The "tilt" function or circuit would be for tilting the motor up and down for trailering/shallow water operation. Couldn't live without it now.
