Tilt and Trim Question
mibowman
Greeting to all,
Have 1986 150 Pro V. Question: Tilt and trim works great until the motor is tilted down as far as it goes. The throtle handle switch will not trim up at this point. I have to use motor switch. It seems as though the throtle handle stops sending power to trim motor in the very down position. As soo as the motor passes straight down the throtle handle begins to work again. Is there some sot of limit switch that would be effecting the operaton???
Thank you.
