Tilt and trim not lifting motor
said
We can hear the trim/tilt motor going but the boat motor doesn't get lifted or downed.
Any input is appreciated. thanks.
boobie
Re: Tilt and trim not lifting motor
First thing to do is check the oil level in it. Loosen your manual tilt screw, pull it up to full tilt and then check the oil level.
Is the manual tilt screw the one seen at the bottom of the motor?
boobie
The screw I can see from the pic looks like the fill plug for the reservoir. The manual release screw should be down on the bottom.
