Tilt and trim modify
lakebum16
Hi guys, just wondering if anyone has or if it is even possible to replace the hard hydraulic lines with some kind of high pressure flex line. I am mounting a tilt and trim unit from a force 50 hp. to fit my nissan 40c. I need to move the electric motor and pump to different position.
rlb9844
Re: Tilt and trim modify
Never tried it, but i work with hydaulics at work a lot. I don't see why it wouldn't work. The only thing is hydraulic hoses are alot bigger diameter than hard lines. If thats not an issue then I think you're good.
