Hello Everyone, I need some help with my tilt and trim. I own a 1988 Force 125 with a 1987 tilt and trim I recently purchased and installed. I had a 2 wire system originally and now have a 3 wire system. After installing the the 3 wire system I had to scratch my head and figure out what I wanted to do with the wire, instead of changing the trim switch and pulling wire to the console I decided to ground the black wire to the engine and wire the blue and green wires to the relays as if it was a 2 wire system. The problem is when I trim "up" it trips the breaker and I have to remove the cover and reset in order to finish. Before I even installed the wire I checked it with just battery power and the trim moved the engine like it was light as a feather (fast) now it is S L O W. What the heck did I do wrong? any help will be much appreciated. Thanks
