Tilt And trim fluid
Bent Prop
Can any tilt and trim fluid be used in tilt pump as long as you follow manufactors specs? Thanks!!
Chris1956
Honorary Supreme Mariner
Gee, I am not sure I understand your question. The OEM will always specify OEM PTT fluid, and might recommend a substitute. I would follow that recommendation.
The substitute can usually be any brand that meets OEM Specs. Normally the substitute is Dextron III ATF. Cranberry Juice looks the same, but is not recommended.
Bent Prop
ok mine takes OEM BRP Johnson Evinrude Power Trim/Tilt Steering Fluid, but my home town doesn't have it, got last tube online. JUst make sure it has the right additives as OEM Right?
Chris1956
Does your owner's manual recommend a substitute, if the OEM stuff is not avail? Normally it would be a Dextron II Auto Trans Fluid.
