Tilt and Trim 1973 chrysler
tjl123
I am looking for the nut that is on a bracket on the tilt cylinder. The nut screws into the bracket and against the cylinder and the line screws into it. Does anyone know what that nut is called and where I can find one
Frank Acampora
Re: Tilt and Trim 1973 chrysler
I forget what it is called but it is damned expensive. It was used on all tilt cylinders fromearly Chrysler up to about 1991 Force. Send a PM to RRitt. He most likely will have one to sell you.
RRitt
I think they are NLA? if so ... the band can be fabricated out of 1/32" x 1" SS strip and aluminum pop rivets. the "nut" is nothing more than an aluminum square with 3/8-24 hole threaded through the middle. you can make one out of 1/8" aluminum stock.
jerryjerry05
F2A654983
CYLINDER BEND ASSEMBLY
Also called a bango fitting??? boats . net about $40
