1995 Force 40hp ........ My relays click when I try to use trim. I have traced the wires with a test light an I got 12 volts but no 12 volts past the relays. SO I unhooked the wires past the relays and jumped the wire an tilt an trim works. I ordered two relays even though I thought it odd up and down does not work. I put the new relays on & still does not work. I cleaned every ground an hot wire in the equation. Still no trim. However, I do hear it "click" at the relays still.
I have not checked the harness female end of the relays. I heard they do not go bad often but mostly I do not know how to test them.
I also have not checked the control box as I get 12 volts past that so I did not think I needed to
Any ideas?
Any ideas?
