Tillotson Idle Tube Part
dmann
I have a 1989 Force 85 HP. It has (I believe) Tillotson Carbs and the numbers on the carb flanges are WE 18-2D, 632061-4. The top carb has a damaged Idle tube. The parts repair list does not show that the part is available. Any suggestions on where one might be obtained. Trying to avoid buying a whole carb just to get a small idle tube.<br /><br />Any help would be appreciated.
The Marine Doctor
Re: Tillotson Idle Tube Part
I replaced one at the begining of the year..I took it out of an older Chrysler 75 hp carb.<br /><br />So in your search for a used one...you should be able to find one easier.<br /><br />Always remember when you disassemble the idle jet, to take out the idle air screw.<br /><br />TMD
dmann
Thanks for the help, I will broaden my search now and post my results.
