Tiller handle hard as %^&* to turn
pro-crastinator
1958 Johnson AD-12 7.5hp
I took the tiller handle apart to the point that - with the rubber-plastic "handle" removed, and the handle thru bolt screwed into the shaft,
you can manipulate the throttle easily with index finger and thumb. (problem is in the handle?)
I can replace the handle WITHOUT the spring and everything is easy peasy - too much. Not enuf resistance.
Are there "parts" that are buried in the handle that I havnt seen yet ?
I have a (stock) brass washer that goes under the spring, press the handle in and align the hole, liberal grease, still too tight.ock)
I know that somebodies crossed this bridge before.
Any help will be appreciated.
thanks
-Bennett
boobie
Is the throttle position indicator on the handle causing the problem ??
F_R
Tapered metal or plastic friction cone still in the handle. Remove it and clean it up and grease liberally.
pro-crastinator
377512-LOWER-UNIT-GROUP.gifThrottle position indicator not affecting problem. Tried it with and without.
Tapered metal or plastic friction cone - will dig it out of the handle and report back.
Thinking its part number 92
Sure wish handlew were available. The one I got is pretty grimy looking.
Wont be able to do the work for several days. Will keep you informed of progress.
thanx
