We just moved into our new marina / slip last Sunday.
Have a 24' toon and the access alley between the docks to get to the slip is maybe 36-40'; bit tight making the ninety degree turn into the slip.
I'm not 'completely' seasoned behind the helm but pretty good handling a vehicle whether it be parking / loading the boat or handling trailers. First time in had my brother on the bow and my wife @ stern with push-hooks to help when close to the dock and / or other boats - especially one accross the alley with his outdrive sticking out a bit.
Old marina had a straight shot in; just had a current / wind to contend with - wasn't a big deal.
There will be times when it might just be one adult and a kid (11-12 yr old) or two when taking the boat out. I'm not comfortable with a twelve yr old being either the one up front or aft to physically help avoid trouble or at the helm yet.
Thought on how much a benefit a trolling motor would be to help navigate into the slip?
We primarily use the boat for general leisure / tubing but will probably start using it more and more for fishing. Thinking about a ~ 50# thrust hand control 12v motor.
Thoughts???
EDIT: Probably looking for something like a Motorguide VariMax V55 w/ a 50" shaft; seemed to be most economical via a quick web search.
What the best vertical position for the prop relative to the tubes?
Any other models we should be looking at?
Hand control seems to make more sense if the primary use is tight quarter navigation. Also prefer something that is compact and does not take up a lot of deck space.
Thoughts???
