Thunderbolt IV ignition rotor removal problem
ducati
i HAVE A THUNDERBOLT IV DISTRIBUTOR IN A 3,4L MERCRUISER. I AM HAVING A PROBLEM GETING THE ROTOR TO RELEASE OD THE SHAFT. IS THERE A TRICK TO THIS SEEMS ITS ON THERE REALLY GOOD. ANY SUGGESTIONS? THANKS
NHGuy
Re: Thunderbolt IV ignition rotor removal problem
Yup, book says you gently pry from both sides by placing 2 screwdrivers 180 degrees apart.
The reason this is necessary is the rotor is held down by locktite.
So have a new rotor available, the one you are removing will probably be NG when you get it off the shaft.
ps. Ducatis are the nads, want one.
ktbarrentine
People I have heard from have had to destructively remove the rotor.... Some use a vicegrips, some use a dremel tool. be careful. Good luck.:p
ducati
Thanks Lieutenant! Have a new rotor was unsure and its tight. Have a 1978 Ducati GTS 900 had it since 78 great bike. Thanks Again, Rick
ducati
Thanks, Think i'll strt with the dremell. Much appreciated
NHGuy
If you can't get it with the 2 levers and have to chop it off make sure to lay some rags under there to keep the shrapnel under control.
