Re: Thunderbolt IV ignition questions
is the dizzy actually spinning ? ,all your grounds to the engine /module good ? new pickup not nessesarily good
Hi guys,
I'm chasing down a TBIV issue and I don't want to beat a dead horse; I would just like some quick sanity checks.
The problem started at the end of last year, and I dd the diagnostics check, and I thought the problem was the pick up in the dizzy because I would have spark when tapping to ground.
I replaced it...still no spark.
I disconnected the grey wire from the tach...still no spark.
So I checked all the connetions again and again, and then swapped coils. Still no Spark
I went ahead and found a used TBIV module and put it on...still no spark.
I hooked a testlight in-line (purple wire - test light - + on coil) The light did not blink as I was cranking...seems to me that woudl be a faulty pick up in the distributor, even though it's a brand new one.
I guess I was just wondering what you guys though, and if there was anything else I need to check? there's 12 plus, volts at the key on.
Thanks.
