Thunderbolt ignition trigger
johnrob
Hi guys,<br /><br />I have a problem with a 1970ish 650SS. I did a carb strip and clean at the beach the other day and forgot to re-connect the main battery ground wire to the engine block after re-assembling the unit. It re-started OK (the wire must have been touching the frame) and ran OK for about 5 minutes then died - never to re-start. There was no spark at all on any plug. I thought I must have fried the control box but I'm now not so sure. I checked the connections and disconnected the mercury tilt switch. I had left the ignition switched on at this point and noticed a healthy spark if I moved the (now loose) brown trigger wire connection around. This implies to me that the box is OK - it's producing a spark. I then tried measuring the trigger coil and discovered no resistance on both coils.<br /><br />My questions are:<br /><br />Is the trigger actually a coil or maybe an opto coupler?<br /><br />If it is a coil what resistance should it have?
Clams Canino
Re: Thunderbolt ignition trigger
It's not opto. If you eliminate the switchbox as the problem it almost has to be the trigger.<br /><br />-W
