Thru Hull Leaking
dsarazen
Hi - bought a 23' Trophy and the previous owner installed a thru hull in the rear below the water line for the bait tank pump. Well, of course, now it's leaking. It's a plastic threaded pipe sticking out with a plastic cap on it. I want to seal it, and rubber expansion plugs are not working. Any ideas short of permanently sealing it? Thanks
not enuf toys
Re: Thru Hull Leaking
where is it leaking? outside hull? from the fitting? inside hose?
3m 5200 works for alot of sealing issues but not sure how you are leaking...
