BackyardKrazy
Thread starter- Joined
- Sep 11, 2015
- 90
I've got my new bottom end on, and a couple of my old props don't fit the same, the spline is not long enough.
I came from an 85hp lower(was on it when i purchased it) back to the original 125 short shaft.
A couple of questions if you gentlemen don't mind...
1. The prop nut and lock washer is a different size. i like to have a spare... what Solas hardware kit will work?
2. the props I have are too long, the shaft is too short. they are thru hub exhaust, that I assume mines a single exhaust? It has the anode bolted on behind the prop
.thanks guys, your always a big help!!
