Re: THROTTLE
THe folowing is a repost...................<br />.(just wanted to make sure it was in here, in case someone else runs into this problem<br />and does a "search"......................in answer to your question,I have no idea. If it is like the oder models,the adjustment is under the rubber grip's cap. It will be a nut with a screw in the center. Loosen the nut,adjust the screw unti it is looser than you want by just a bit.Then re-tighten the locknut.. If it is not there, (under the cap), look at the outboard-end of the tiller,and look for a tensioner there. It may be, that it just needs a little lubing. Undo it from the carb (it is attached in the same way as some bike hand break cables, if you can picture that.<br />Try it dosconnected, and see if the tension is still there when u twist. If i isn't, the problem IS in the carb mechanism.However,I would be suprised if the problem was there.<br />They don't sieze-up there under normal use usualy.<br />Good luck<br />And standby for other, more on-track replies..The guys here are great. And someone,no doubt, has run into the same thing you have on the exact same egine.
