Nightfisher-
Thread starter- Joined
- Apr 13, 2010
- 129
I just traded for a 1978 Harris pontoon and one of the things I needed to fix was some yahoo mounted the throttle control box on the left side of the steering console and turned it 90 degrees. (top facing back keys down) Today I bolted a board to the rail to the right of the steering console and moved the shifter to it. After putting it back together I found that It will not go into gear, either forwards or reverse. Idle control moves fine though. Had it apart at least 5 times trying to figure out what I did wrong when I put it back together, but no luck. When I moved it I did not remove any cables. I instead cut a narrow groove in the deck that will be covered by the steering console once it goes back in. The only thing I did when I moved it was took the cover off, removed, cleaned and lubed the cam inside and reassembled it. Any ideas what I put back together wrong that is keeping it from moving? Perhaps the idle lever or cam needs to be in a specific position when put together?
