I have a 97' Force 120 that I just purchased for my pontoon.
I seperately purchased a US Marine control box with all the cables and hook up.
Everything matched and hooked up easily, but when I took the boat for its first ride, forward on the control box was reverse for the motor and reverse on the control box was forward.
Sadly the reverse application at the control box does not get you full throttle.
Do these two products NOT match or can the control box be switched internally? I took it apart and the two cams that operate the shift linkage do not appear to be reversible.
The guy I bought the motor from just changed the impeller. Can the shifter linkage get switched at the lower unit?
Thanks!
Thanks!
