throttle problems
kenneth85
40hp evinrude late 60s not sure of model number. when at full throttle the boat will not go like its suspose to. barley go! could this be a compression problem if so how do i test the compression.
Daviet
Re: throttle problems
You need to start with some basic checks.
Check the local auto parts stores and see if they rent or loan compression testers and check yours.
Check the spark with an air gap tester, should be bright blue and jump 1/4" with a snap sound.
The last thing is fuel delivery system, any leaks, does pumping the primer bulb help the problem, when was the last time the carb was overhauled?
