Throttle on a 57 Johnson 18HP
57 Johnson
First I would like to say that I have been on this site as a guest and found it full of great information. As I am now I'm getting back into fishing and using an older outboard I figured it was time for me to become a member.
I have a 57 Johnson 18HP FD-11. The screw to set the idle was broken so I disassembled the tiller arm to remove the bracket. I was successful at removing the screw but when I reassembled everything the throttle seems very tight. I looked for a drawing to make sure I assembled it correctly but couldn't find one of the tiller arm.
Any help would be greatly appreciated.
F_R
Honorary Supreme Mariner
There are a couple of plastic bushings that the shafts go through. They are notorious for tightening up. It is caused by corrosion around the outside of the bushing. Cure is to dis-assemble the offending part and cleaning the corrosion out and reassemble with some good waterproof marine grease.
Also, make sure the tapered friction plug in the twist grip is greased.
