Throttle not opening all the way
spacro
Ok I have a johnson 115 with a 73 model johnson shifter. I just replaced the f/n/r cable and now am having issues with the throttle. When the shifter is in forward the throttle opens up 100% but in reverse it barely opens. Im not sure if this is correct so this is why im on hrte asking for any info available. Thanks
boobie
Re: Throttle not opening all the way
If you have all the cable adjustments correct, you won't get full throttle in reverse.
