Throttle linkage adjustment
Fiddlefire
Okay I have messed with this extensively and was never right from the beginning. Here are my pictures and let me know where it needs to be set at start/idle. Need some help on this one. (70EL76D)
Joe Reeves
Soooo... Ya'really screwed it up did'ya? :)
Make sure that the measurement of the threaded cam rod is exactly as the graphic below.
Click image for larger version  Name:	75_70HP SYNC LINKAGE1a.jpg Views:	1 Size:	56.2 KB ID:	10647605
Now.... Temporarily back the throttle roller away from the cam so that it has no effect on the carburetors.
With the carburetor face plate removed so you can view the throttle butterflies if needed... adjust the linkages between the three carburetor butterflies so that they "all" start to move (and stop) at the same time. You do not want a butterfly closed and one (or more) held open ever so slightly at idle.... Also, make sure that at full throttle (engine NOT running), that the butterflies are wide open (Horizontal).
Now... adjust the throttle roller so that the throttle butterflies just start to open when the scribe mark of the metal cam is dead center of the throttle roller... not before or after.
The throttle roller!..... For many years the roller was just one piece (3/8" dia) and served us well. Then some engineer in all his brilliance decided to design a two piece roller.... a smaller black roller (approx 1/8") with a clear plastic or nylon covering over it to bring it up to its original 3/8 diameter. The clear covering is worthless, cracks, breaks, falls off, with the resulting smaller roller now throwing the engine completely out of synchronization.
Should you, or anyone reading this reply, encounter a redesigned roller that this genius came up with, that is faulty... replace it with a proper sized 3/8" diameter roller before touching any of this type linkage!
That should do it.
Fiddlefire
Hey thanks Joe. It was pretty screwed up when I got it and for sure did not know how to make it much better. This should work out good. i will let you know the result when I get around to it. Work gets in the way!
Thanks very much!
