throttle issues
AnchorsAstray63
My Motor is a 1959 Johnson 35hp I believe model RDL-21. I got it started for the first time since I bought it which actually went very well. I can't get it to run for more than five or ten seconds. My throttle control is pretty basic, it is labeled slow fast and start. It won't start with the lever in the start position. I can only pull it halfway to slow from there before the lever stops. It won't go to slow, however it will start at that stopping point. I held the lever firmly at that point and was able to keep her running for about two minutes. Any ideas. I have considered cleaning the carburetor and the possibility of poor fuel/air mixture but can't stop thinking of my odd throttle dilemma. I still don't know much about these things so anything helps, thank you.
F_R
Honorary Supreme Mariner
No Title
The markings on those throttles are never accurate. Think of it as fast is that away and slow is the other way. It won't go to Stop unless you back the idle speed adjusting screw way off (NOT the slow speed needle valve).
Don't waste your time or money on it until you check the compression to see if you have anything worth fixing. Once you are satisfied with that, pull the flywheel and inspect the ignition system. I'll guarantee the coils are shot (cracked) unless they have already been replaced.
AnchorsAstray63
That makes sense. I'll give it a look after work and let you know what I find. Thank you very much :)
