THROTTLE CONTROL ROD adj '63 Gale 40 hp
trebot
What is the procedure to adjust the throttle control rod. It has set-screw on the rod & I don't know where to set it .
boobie
If we're talking about the same thing it sets your idle speed.
trebot
No. It is on port side of motor and runs from the vertical throttle shaft to the carb. Its a wire rod with a set screw collar that can be adjusted.
Honorary Supreme Mariner
Usually at idle there is a gap of 3/16" to a 1/4" there.--Try that.---That is often adjusted by folks because it " looks wrong " when it is correct !
F_R
No Title
1. Put motor in forward gear.
2. Advance throttle till the mag plate rotates to full spark advance (it will bang up against a projection on top of cylinder block).
3. It should now be just touching the set collar, ready to push the carburetor butterfly open with continued advancing of the throttle control over-center of the spring atop the vertical shaft..
trebot
I thought that was the adjustment, but I wanted expert opinions. Thanks to RACERONE & F_R.
