Throttle cable tension Merc 4.3
Kubaat3lover
hello folks again,
My drive is finally aligned and installed, carb after rebuilt during the winter installed,
But I’ve found tension while connecting the throttle.
Is that correct or should it be readjusted?
The video shows the problem, it’s “longer” than the throttle lever and while installed there is a quite pressure on that
Kubaat3lover
I cant edit my post, found info about cable preload.. but how much preload is fine?...
