how do i know if i have to replace my throttle cable? i have a 1996 stingray 556 and i was cruising in barnegat bay when i hit some big wakes and slammed down pretty hard. immediatly the engine rpm's slowed and the boat slowed down but the throttle was in the same position. it then happened again a week later after another run in rough water. both times i would place the throttle in neutral and accelerate normaly again. i noticed adjustments on the carb side and a slide system. do i need a new throttle cable? its not a huge deal but annoying in the rough stuff. also i dont want to be out and have it not return to normal after i put it in neutral!!!
