Throttle cable adjustment
Zook4184
Hello everyone I have a 1989 88spl evinrude outboard and I have a omc remote control I can not figure out how to get this cable adjusted rite I cannot get the warm up throttle to give me any rpm change I have adjusted this thing all different directions I have taken apart the controller and really don’t see anything broken or worn but I’m not really sure what I’m looking for I don’t know how to determine if cable is stretched any help would be appreciated thanks
saltchuckmatt
When you shift into gear does the normal throttle work?
saltchuckmatt
Hello everyone I have a 1989 88spl evinrude outboard and I have a omc remote control I can not figure out how to get this cable adjusted rite I cannot get the warm up throttle to give me any rpm change I have adjusted this thing all different directions I have taken apart the controller and really don’t see anything broken or worn but I’m not really sure what I’m looking for I don’t know how to determine if cable is stretched any help would be appreciated thanks.
If your throttle is working, watch this video. His terms are incorrect but he points to common problems.
Zook4184
I want to thank you for the advice I watch video twice and pick up the warm up throttle nut could be loose took controller off tonight tighten nut which was loose re adjusted cable works beautifully have full range of warm up lever something so simple was driving me nuts thanks again
saltchuckmatt
Excellent, and thanks for letting us all know.
