Re: Three Phase Electricity
GQ-<br /><br />Thanks for the diagrams. I am pretty sure I get the concepts that you are describing. I'm assuming when you say "Neutral" you mean a current carrying conductor bonded with Earth.<br /><br />On the boat, it doesnt look like we have an earth-bonded neutral and dual voltages are achieved through transformers. If it is correct that a single voltage three phase system does not require such a neutral, then I am fairly confident this is how the 110 system is derived on our ship. My 110 panel has three incoming leads, if I measure across any two I get 110, and measuring any one to the hull (ground), produces something along the lines of 75-80. This seems to mimic a three phase system fairly well, and it wouldnt require a neutral bonded to earth (through the hull) if the above assumption is correct (that single voltage three phase doesnt require an earth bonded neutral). <br /><br />What I was saying before was that if this is the case, then it wouldnt be correct to just take one of the 440 leads and the hull to make 260 volts or whatever for the galley range, because based on the way the rest of the boat is wired, I'm not supposed to be using the hull for anything. I'd need another transformer. Then I could just take two of the lines coming out of there, (making 240V) and wire up the range, but the range still wants a neutral wire based on the installation instructions, and there would be the issue of where to put that (since it cant go to the hull).
