Re: Three Phase Electricity
Believe me I have no intention of actually touching any of this, that's what the electrician is for. He is doing some research, talking with electrician buddies, and studying wiring diagrams before he even touches it.<br /><br />OK forgive my crude, probably wrong analogy, but this is what I am envisioning. The electric motor is a swivel chair and the electricity is someone standing next to the chair and is going to spin it as fast as he can. If he is three phase, he will push the chair three times (at 120* intervals) per revolution, whereas if he is single phase he'll push it once per revolution, so he only touches it in the same spot each time it comes around. If he wants it to go the same speed as if he were three phase, he would have to push it much harder (with more amps).<br /><br />What of neutral and grounding in three phase? <br /><br />There are a few reasons for my asking which may help put my question in context. First, I am simply curious since I don't get it <br /><br />Second, we're installing a household range in the galley, in place of a 440 cast iron unit that didn't work. The electrcian says we're probably going to have to use a transformer to make 220 for the range, but what of a neutral for lower voltage things like the indicator lights and whatnot on the range, and a ground? Where do those come into play in the three phase system and thus the boat as a whole?<br /><br />Third, can three phase be used for 110? We have 110 electrical panels on the boat, each with three leads coming in. Those leads, however, go right back to a breaker on the main distribution panel. On the bottom (output side) of the breaker are these three leads to the panel, on the feed side, it looks like it just comes off the three phase system. There are three grid bars in the 110 side of the main panel one for each of these leads that go into the panel (still with me?). The electrician said the whole main panel was hot, which led us to believe this was some kind of three phase 110 set up. If so, how does it work and where is the neutral and the ground? The thre leads in the smaller panel are labeled H, N, and G, but they just go back to the breaker on the main panel, I dont know if the labeling can be trusted.
