My 1975 70 hp Seahorse has had three remanufactured powerheads installed on warranty in three years because of water in the cylinders. The shop says this is just bad luck with the rebuild job, but I wonder if there might be something wrong with the surfaces on top of the lower unit that match up to the bottom of the powerhead. The shop says no, they would be able to see any problems there. Is this "bad luck" common or, if not, do you have any suggestions? I'm kind of stuck with these folks because of the warranty.
