smokeonthewater
- Dec 3, 2009
- 9,838
Re: thinking of purchasing 1990 sea ray bowrider - what am i getting into?
congrats and welcome ye land lubber to the sea.....n stuff
Well...i went ahead and pulled the trigger. According to the mechanic, the 135 hp merc had been more or less completely rebuilt. Also new impeller.
The boat started on the first crank in the dealer parking lot, and then again when I put it in the lake. It was free of soft spots (nothing spongy, one spot between the windows in the center of the boat a little "bouncy"). Transom was solid.
So i took the plunge - paid $2750 including sales tax and registration for the trailer and boat. Trailered back from Orlando to Indian Harbour with no issues.
I do have a couple of questions though (I'm sure I'll have many more as I go). First - the boat will not start when the motor is trimmed all the way up. When the motor is trimmed down, it starts on the first crank. is this typical for a 2 stroke OB with carburetor?
perfectly normal PLUS you shouldn't be TRYING to start it when tilted up
Second - the boat will be stored on a lift at my house (no roof over the lift). Do i need to pull the drain plug if I'm going to cover it with a polyester or acrylic cover? Its hard enough to get the "ears" on to flush it (i'm running in salt water), but getting the drain plug in and out while its on the lift is damn near impossible. Thoughts?
Can you get the plug in and out from the INSIDE of the hull?
you can leave a plug in... bilge pump with auto switch should be on the boat anyhow.
