rose_surfer
- Dec 24, 2012
- 8
I'm thinking of purchasing a 1990 sea ray bowrider from a dealer in Central Florida. it will end up being under $3,000 including the trailer. I grew up around boats, but this would be my first.
Question is - for a boat this age, am i pretty much guaranteed that there is stringer and/or transom (water) damage and/or rot or some other really significant problem?
I suppose I could invest in a thorough survey, but I also feel like for under $3k, if the engine cranks fine, the deck and transom feel solid, it shifts into gear with no grinding, and it runs well on the water, including the bilge, etc., and no water comes out when I pull the drain plug after taking it for a 10 minute run then I'm probably doing ok. Thoughts?
Am I better off spending a couple thousand more for a slightly newer boat? I'm not really in a position to spend more than $5k or so, but just want a fun family "starter" boat.
