thinking about changing my timming cover my self any tips? thanks...
mr rookie
hi all , im new here and newer to boating just bought a 98 searay 180 br. w/ a3.0 merc. w/ an alpha 1outdrive boat runs supurb. had it for 2 mo. and now discoverd that it's leaking a small amount of water and oil and only does this under a load NOT ON EAR MUFFS OR SITING. witch makes a mess in the bildge when ur out on water. i had googled this and found that in most cases like this w/ this motor its the water pump leaking water over the timeing chain cover over a period of time itrusts out and get s lil pin holes.im just a carpenter so one i dont have 2000 or so to have the stealership do this for me . i think i can do this w/ out pulling the motor my back seats come out and motor is opean all the way down to the bottom of the block so it looks like i can accsess all i need to. one question i have some say u must drop the oil pan? another said u can cut back the gasket and get away w out? then im thinking about blocking the motor at the bottom w/ safty chain holding up motor so i can pull the front motar mount w/o stress on the outdrive. any ideas or hints that will help me along the way?:facepalm:
mr rookie
Re: thinking about changing my timming cover my self any tips? thanks...
what s up any help here
natemoore
Master Chief Petty Officer
My engine is a 470, so I can't talk about yours, but I will say that if you buy or download the appropriate Mercruiser engine manual, have the right tools, and can follow directions, you could tackle a complete engine rebuild. So go for it. This forum is a huge help, but sometimes it takes a while for people to chime in.
mr rookie
this i see, well bought a book, a harmonica ballancer puller/installer a tor.wrench and a comealong to suport front of motor think i have all i need. this book is nice..
fat fanny
Let me know when you get that harmonica balanced!!! Just remember that when you pull upward on that engine the possiblities of the O/D being moved out of alignment to the motor are very high!!!!
stonyloam
Agree, if you touch the front motor mounts you should pull the outdrive and realign when you are done.
mr rookie
ok now im scared,i can pull the outdrive by the 4 bolts right? what do u mean relighn it. what willshift? and u must ballance the harmonica balancer?confused now
mr rookie
should i pull the motor? and how much would i really half to lift up i thought just puting tension to releasemotor mount am i looking at this all wrong ?
stonyloam
There are 6 bolts. Alignment: The drivrshaft for the outdrive goes through the gimbal bearing into the engine coupler. The engine must be set so that the driveshaft goes absolutely straight through the bearing into the coupler. If you raise or lower the engine on the front mount it changes the alignment and puts stress on the bearing and coupler causing either or both to fail. If you raise it and put it back to where it was, chances are that the alignment will be off. You use an alignment tool to make sure everything is straight when you put it all together again.
mr rookie
thanks this is all great info very well apperciated so what would u say i have a1/4 inch grace or no ??:confused:
stonyloam
No! The only to make sure is to get a mercruiser alignment tool (about $40 e-bay) and make sure.
mr rookie
well now where up 2 $250.00 in tools to complete job ouch any mor things i should know or have?
stonyloam
Don't you just love boats? If you can see where it is leaking, and get to it, clean it off really well and give it a coating of JB Weld, cost about 6 bucks;). I plugged rust pinholes in my lawn tractor fuel bowl that way 4 years ago and it is still holding. Good luck.
natemoore
Come on now. You know it's harmonic balancer. You're just messing with us!:D
natemoore
The procedure is so exacting that one technique calls for coating the alignment tool evenly with grease, shoving it into the coupler, then determining which way to move the engine by the thickness of the grease left on the tool. I spent hours interpreting the tea leaves (grease thickness) and tweaking the engine mounts.
natemoore
Take a look at some of the improvised tools I made during my 470/alpha one rebuild. The only one I really had to buy was the alignment tool since I don't have access to a metal working lathe. However, with some ingenuity or reverse engineering, you can make many of the tools you need.
http://forums.iboats.com/showthread.php?t=353035
mr rookie
yes as much stress and money iv went thro u think it was a women problem not a boat thanks for all the tips many more welcome not feeling good about this yet.:facepalm:
mr rookie
hey guys so i started this job all went good untill i pulledoff the harmonic balancer anf found my crank shaft is not threaded. so how do i press this back on. do i need to have this tapped? or has someone ran in to this ,and or know a tool that u can use to press this back on with out threading in to the harmonic balancer im stumped please help soon as any one can chime in back at it tomorrow.
natemoore
As I recall, you remove the crankshaft bolt then pull off the harmonic balancer. For installation, you just screw the bolt back in and torque it down.
Now, are you saying that there are no threads on the inside of the crankshaft? Did you not have to remove a bolt first before pulling it?
