Think I blew a fuse-don't know how to reset?
tlboehm
Hi,
I was installing a Hummingbird fish finder on my pontoon and arched the positive ground to the negative, on Aux switch, by my fuse panel. I was wondering how I reset the fuse on a Seadog Vertical 6-Gang Panel? It did not pop out like I assumed it would. Now I do not have power between the fuse and the switch.
Thanks for any suggestions.
MLD
Re: Think I blew a fuse-don't know how to reset?
maybe there's another fuse that blew closer to the battery.
tlboehm
I still have power to the horn and lights above the Aux.
RickJ6956
Square red buttons labeled "Fuse"?
Use a ballpoint pen or small screwdriver inserted into the side slot where it says "Push". Cover it with your hand as you release it -- the fuse and cap will pop out.
tlboehm
Thank you I will try it.
Silvertip
Honorary Supreme Mariner
You don't reset a fuse. If it blew it must be replaced.
RickJ6956
Also, those aren't buttons. But I'm sure you've figured that out by now, tl. ;)
