thin or thick epoxy
proshine43
hello all, Im about to oreder my epoxy resin from us composite for my hull and my deck, they have 2 different types, a thick resin and a thin resin. which one do i need. im thinking the thin but im double checking with you guys. also which mat do i need, their 1 1/2 oz or their 2 oz mat. im waiting to find the answer till i hear from you experts. i have the form filled and my finger on the submit button. thanks again
Woodonglass
Re: thin or thick epoxy
Well it would be nice if we knew what you were going to do with the resin and the glass.
I'm just sayin...:D
proshine43
sorry about that, i will be building up the hull where some of the layers have come off due to soaked foam, and also i am redecking the boat, and i will be fiberglassing both sides. also i will be fiberglassing the new stringers. thanks
Woodonglass
I would recommend the Medium Epoxy resin kit. Ket the Pump kit too. It is really worth it when it comes to mixing it correctly. For your hull and stringer I would use 1708 biax. For the deck I would use 6oz Eglass.
I'm just sayin...:D
proshine43
ok i just ordered the thin medium epoxy resin, the 1708 for the hull and the stringers, and the 6oz eglass for the deck, how many layers should I do the deck and the stringers in. I was thinking 1 layer on bottom of deck and 2 layers on the top of deck and 2 layers for the stringers. thanks:)
Woodonglass
You are SPOT on on your layers
Good luck with your project.
Post some pics so we can all enjoy your progress
I'm just sayin...:D
proshine43
thanks woodonglass for your help, much appreciated, My order is placed. cant wait to get started
