Thermostat
WannaFish
I have a 1967 Evinrude 60HP sport four. I need to get to the thermostats, I believe they are located behind motor between cylinder heads in a box with two hoses going to cylinders. I remove 5 screws that holds top of box on but still won't come off. Any ideas.
Joe Reeves
Re: Thermostat
If you have indeed removed all of the retaining screws, and none are broken off, the top portion is simply stuck.<br /><br />Hold on to it, then tap it sideways. It should break loose. Note that there is also a spring loaded water relief valve under that cap.
