Texasmark
- Dec 20, 2005
- 14,916
Just bought this boat and have had it out 3 times in the past 60 days. As mentioned in another post, the thermostat was stuck closed and I limped home.<br /><br />Since Merc did without them long after OMC introduced them I said what the heck and tossed it.<br /><br />Was out again yesterday and in cold weather this engine is really thirsty trying to get her going at launch. I thought that maybe I should put another stat in.<br /><br />But I have a couple of objections to that (thoughts/questions).<br /><br />1. Upon entering the lake with a cold lake and cold engine, the stat will do absolutely nothing to help you get you started the first time. Will agree that subsequent starts could be easier, but they are easier anyway. Like touch the key and she's a running, no throttle advance necessary.<br /><br />2. This engine has a water pressure relief valve that is forced open when you plane out and get some water pressure on the water inlet holes in the skeg. Opening this valve bypasses the thermostat and allows lake water to run freely thru the engine's cooling passages.<br />---------------<br /><br />So if I'm running flat out it's useless and unless I stop and troll for awhile, or putt around at near idle speed I get no benefit from it.<br /><br />So did I miss something?<br />----------------<br /><br />Then there's the matter of temp. The pellet on mine was stamped 120 degrees. Noticed at least 1 www site that has after market stats for sale and you can get some hotter ones. But if you get too hot your cooling passages are like a hot water heater and build up scale and plug. Any thoughts here? I realize that 120 degrees is warmer than a 40 degree lake, but I already went thru that.<br /><br />Thanks,<br /><br />Mark
