Wyomingman
Thread starter- Joined
- Mar 26, 2009
- 38
I have a 2002 Mercruiser 4.3 MPI. Today I took it out for the first run of the season. LAst fall I winterized it by taking off the thermostat housing a pouring anti freeze into the block. The thermostat housing was "stuck" on when I first took it off but with a lttle tug it popped off. Today I noticed some water spraying out of the housing where it meets the block. I don't remember an o ring or gasket on this and when I pulled it off today, there was none there. I am thinking since it is metal to metal where it meets there should be some kind of seal? Is this correct? Do you think thats why it is leaking????
