Thermostat for 855470 - thermostat housing
Schonl
Hello everyone, I need a little help finding the correct thermostat for thermo housing 855470. I have mine out and see no part numbers on the thermostat. The engine is a chevrolet 350. The problem I have is that the plate on the motor with the volvo penta motor number was removed at some point in the last 20 years so I can't look up any parts. Any help would be greatly appreciated! Thanks.
Fun Times
Using a 260A engine model should get you what you need.
Volvo T/Housing part number 855485 = 855470 evident if you zoom in on this photo, http://www.boatersland.com/vlp855485.html
Volvo thermostat part number 876305 fits the 260A, http://www.volvopentastore.com/Cooli...view_id.783506 < Also don't forget items numbers 36 and 37.
Genuine Volvo Penta Thermostat Kit V6 & V8 AQ Series Engines - 144? (degrees) Fits Volvo Engine Models: ◦ AQ175A AQ205A 430A 430B 431A 431B◦ 432A 434A AQ190A AQ200B AQ200C AQ200D◦ AQ200F AQ211A AQ225B AQ225C AQ225D◦ AQ225E AQ225F BB225A BB225B BB225C◦ AQ231A AQ231B BB231A 500A 500B 501A 501B◦ AQ240A AQ255A AQ255B AQ260A AQ260B BB260A◦ BB260B BB260C BB261A AQ271A AQ271B AQ271C◦ AQ271D AQ280A AQ290A AQ311A AQ311B 570A◦ 571A 572A 740A 740B OEM Volvo Penta part #876305 Replaces Volvo Penta part #876305-4
Schonl
Thanks so much for the info, I will be ordering it today. This is my first I/O so i'm still learning the system. Now that I have a engine number to go by it should be a lot easier. The model you gave is exactly what I have. Thanks again!
