jdwilliams1
Thread starter- Joined
- Jul 25, 2011
- 40
Ok, have made my way through timing, plugs, new cables, points clean and adjusted, so now I am onto fuel I believe.
Keep in mind I have not cleaned the carb yet but that is on the list and may be causing this issue.
I am finally able to start the engine. I can start it sometimes with the choke off and sometimes in auto choke, strong smell of fuel at the carb. Once it does start it will a idle for 15 secs, then 30, then it idles pretty good for a while but after a couple minutes a good deal of smoke starts to appear and it becomes pretty thick in the water barrel and around the motor. Any thoughts on this?
Also, I have a couple images of a hose and water was slightly leaking from it. I know I need to replace the hose but should water be leaking from it? and can this hose be bought at local hardware store and if so what is it?
