jasoutside
- Dec 20, 2009
- 13,269
Did you guys catch this 2015 Ford?
Aluminum :joyous:
Aluminum :joyous:
Aluminum :joyous:
huh.....BF, you're the LAST guy i would expect to think this was a good idea......i was just discussing this with a colleague. aluminum works for Acura NSXs, less so for Audis, not at all for pickup trucks. IMHO. imagine a truck body that looked like your hull.....
And so what are you saying Jason, You think were cheep up here.:rant:
Despite the increased costs, Douglas W. Scott, Ford Truck Group marketing manager, insisted the new truck's pricing would remain about the same.
"The current F-150 ranges from $24,000 to $50,000," he said. "Our intention is to cover the same price range."
Another issue raised by the aluminum cab and bed is how it will sit with a rather traditional base of buyers long accustomed to steel's ruggedness.
"We've done a lot of homework and we've found that 80 percent of our customer base understands that aluminum has strength as well as being weight-saving," Scott said. "Most people get it."
It's also true that the remaining 20 percent apparently aren't so sure.
"That means that 140,000 are skeptical," Phillippi said. "That's a lot of skepticism."
While there may be some discontent in the market, Ford maintains the new truck is the strongest, most durable F-150 ever. The company says the aluminum alloys employed in the cab and bed are very strong and more dent- and corrosion-resistant than steel, adding that the high-strength steels and design employed in the frame make it even stronger than its predecessor.
But GM likely won't be able to implement an extensive weight reduction program until the just-redesigned Chevrolet Silverado and GMC Sierra are overhauled again in 2019, according to supplier sources. That is five years after Ford plans to slash at least 700 lbs (318 kg) from its best-selling F-150 pickup as part of a fall 2014 redesign.
One supplier source said GM plans to introduce late next year a special aluminum-intensive version of the Silverado that could be up to 250 lbs lighter, with 20-percent better fuel economy.
