JasonJ
- Aug 20, 2001
- 4,163
It was a great day, temps in the 70s. I got done with work early, and started glassing in the transom. I went ahead and whipped up a batch of resin and grabbed my precut transom wood and fiberglass mat. I wetted out a layer of mat on the hull, layed in a 5/8th piece of ply for the transom, layed in another layer of wetted out mat, and layed in the second layer of ply, 3/4 inch this time. I ran bolts with large washers through all thru-hull holes, clamped the edges, and braced the bottom areas of the transom wood with 2x4s. Finally, screwed the two layers of wood and mat together with stainless screws. Let it kick out, trimmed the mat that was sticking out around the edges, and thats that. Next step is to finish it by encasing the whole mess in glass, but I will whip up some thickened resin and force it in under all the edges and radius it out so there isn't sharp corners. I'll post pics after it is all glassed in.
