First on the run on paragraphs, which always look fine in preview;
When I post this, most likely it will end up jammed at the end of the first line. Even though I use carriage return (Enter) at the end of every paragraph,
this line will be jammed.
But if I insert a horizontal line from the Advanced Editor,
The paragraphs are separated by the line and I can make something a bit more readable. It doesn't look pretty, but legibility of the end result is better. So instead of six lines in a run on paragraph, with the horiz. lines this post will, if it runs on, will have the first three lines jammed and the next four will be forced into separate paragraphs.
So the first part of this is turned into this by using lines instead of carriage returns (Enter):
Basically, I'm using the inserted horz. line instead of a carriage return (Enter). Lets see what happens after posting.
EDIT - Even edit runs on without the line.
EDIT - Even edit runs on without the line. BTW - I haven't checked with other browsers, This is the latest Firefox.
