Fix a Floot
- Apr 21, 2011
- 2
1st probe hole with small stick magnet aslo compressed air shot in hole at different angles makes it move some time. This makes the bar nut that should be glued in atainable remove it "if not in there good for you" move to next step Go get a Rubber freeze plug expandable type at auto parts $3.00 size is 1" to 1-1/8" grind rubber flat spot to make it match housing hole feel with finger to see what I mean put in hole tighten DONE GO BOATING
