13crazyhorse
- Apr 4, 2010
- 147
I just bought a 86 four winns with a 350 engine. I don't have any spark. I've got the chart on how to diagnose this. I got down to where it says remove high tension lead from distributor to coil. Insert a spark gap tester from coil wire to ground. Remove wht/grn lead from distributor terminal - ignition key in run position. Strike the terminal on the wht/grn lead against ground. I have a couple of questions. I have a spark plug spark tester that plugs on a plug and then into the plug boot is that the same? I don't understand how this would hook to the coil? Can I just use a wire with alligator clips to ground the coil? Then I already removed one wht/grn wire from the dist in a previous step that went to the interrupter switch but there's one left I assume that's the one to remove. Then I strike the removed wire against a ground? It says one way there will be spark at the coil and one way there will be none? I'm missing something, please explain for the dummy! Thanks ahead of time for your help.
