Testing ignition system - 1980 Merc Inline 6 Thunderbolt Ignition
hempfarmer
Hi there,
Just looking for some advice on how to check my ignition system. My boat stalled towing a skier at 4000 RPM and after this it won't idle very well and WOT is now 4000RPM instead of 5400 RPM. Sounds like I am missing a cylinder. My mechanic was testing my stator this spring and he found it was just within specs but felt the readings didn't hold very steady so I kind of expected it to go at some point.
I don't own any of the tools so I am going to do the following:
1. Buy a spark tester and run test.
2. Buy a DVA meter to verify if my CDI stator is within their specs. I am going to do this without actually running the engine.
Can you think of anything else I can check on my own? Oddly I am hoping my stator fails the test so I can swap it and the switchbox out. More piece of mind knowing those parts are new anyway.
Thank you.
Russ
canoemang
Re: Testing ignition system - 1980 Merc Inline 6 Thunderbolt Ignition
That is a proper spark tester. Most parts stores have them same or similar for $10.00
Here is a Ignition test guide from CDI:
cdi ignition testing
hempfarmer
Thanks for the link. Man those DVA meters are hard to find in stores...
canoemang
Go grab one from Ebay..
here is the one i grabbed earlier this season.. works great.
DVA METER
Check your compression first. If it is good, proceed to the spark test.
