I have a 1981 Mercruiser 228 HP (305 ci) with a mechanical fuel pump. From what I have seen posted on here, the correct way to test the fuel pressure is to do so while running under load? My question is, Can an accurate pressure reading be taken using the starter to turn the engine over, but not actually running the engine? I hooked a guage to my fuel pump and got only 3 to 3.5 psi doing this. Just curious to know if this is an acceptable method of testing, or do I need to take the boat out on the lake and test under load?
