Testing Compression
SeaMasterZ@aol.com
when you test compression, do you take it on ONE pop, or do you crank it over a few times? Seems to me that compression might accumulate over a few pumps and not give an accurate reading<br /><br />any thoughts?
corm
Re: Testing Compression
Hi Ray,<br />I always pump them up till the gauge reading is stabill. As long as you do the cyls the same you will get a good idea of your comp.
